Lighting | on ElectriciansForums
Discuss Lighting in the Australia area at ElectriciansForums.net
T
TedMason
Hallo, i have 4x lighting boxes for a wall in a shop. All have 4x36w fl/tubes in them. I have connected them together with a double pole switch and put on a plug top. What plug fuse should i use as 5amps blow? Thanks. Ted.
Reply to Lighting in the Australia area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
Thank you so much for your help with this light work perfect now thank you again much appreciated
