Lightning Conductor | on ElectriciansForums
Discuss Lightning Conductor in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
paulwilliams
if i have a conductor connected to the metalwork of the building how do get a test reading ?
need a bonding test, involves using a generator and a special test set, look up lightning rod company on google or yellow pages, should cost about ÂŁ70...
Better if you could tell us what your trying to do as far as testing is involved?? Is the connection a removable connection or not?? If it's a welded connection and if the metal frame of the building is being used as both the down conductor and the ground electrode, there is little you can test, apart from the overall Ra value....
Need more information to guide you further....
Reply to Lightning Conductor in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I thought it was just a head with a link, rather than a fuse. Just strange that it can be so easy to pull it out. Different if it was a lid which...
I have this Adee Fusadee lightning arrestor in my electrical cupboard, the area I’m in is prone to thunderstorms from spring to autumn so it is...
