Lights and add a controller switch / watts | on ElectriciansForums
Discuss Lights and add a controller switch / watts in the DIY Electrical Advice area at ElectriciansForums.net
Uk
hello everyone
I don’t know much about electricity but I’m looking to do a little diy project.
I bought some lights now the lights say max 0.75 watts and I’m looking to add a controller to lights and that’s says it outputs 144wats will this cause a fire or some sort of unsafe project
Thank you for reading and helping
So this is what I purchased
Upload the image directly to the thread: The magic of the Internet - https://Upload the image directly to the thread.com/a/eumGZof
And I’m looking to cut the cable that connects to the power supply/controller (the box with two wires coming off it) so I would have the little box where the lights connect too and to replace it with this
Upload the image directly to the thread: The magic of the Internet - https://Upload the image directly to the thread.com/a/JCeBmQy
But I’m not sure if it will work/be safe
Because the little hub thing wear all the lights connect says max 0.75 watts and the controller I want to says it outputs 144watts
Thanks for reading
[ElectriciansForums.net] Lights and add a controller switch / watts
this one
Alright then
Thank you very much for the help buzzlightyear it was much appreciated
Reply to Lights and add a controller switch / watts in the DIY Electrical Advice area at ElectriciansForums.net
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
Dry contacts or voltage free contacts is correct. The ones you linked to would do the job. These ones are well known and highly recommended -...
loz2754
L
