Evening all..
I came across an interesting one today that I had not seen before.
I had a simple job of like for like replacement of some ceiling lights. I switched off the lighting circuit but the lights stated on, not too unusual you may think. I then switched off the rest of them one by one and the lights went off with the shower MCB. I then switched the other breakers back on and the lights came back on with the lighting circuit breaker!
I then noticed an unswitched fused spur (in 1mm) from the shower switch which supplied power to the 2 lights I was changing. Then I switched off the shower circuit and noticed that the shower was still live as it was coming through the lighting circuit and then through the 3A fuse!!
Has any one else come across crossed circuits like this? How could it occur? Why would someone do that as the lights already had power so why then give them another source?
