V
voltage
Hi all,
Got a problem at my mum and dads house the house is a 1991 build its a PME system with a crabtree consumer unit with rccb.
The problem they have which just happened today is they have a fan light in kitchen which holds 3 bulbs and the switch does this fan light and the fluorescent in the garage. Now the garage light works fine but when you switch on fan light the bulbs pop and blow which trips the rccb and the mcb for downstairs lights.
This has never happened before ive taken the switch off to have a look nothing obvious no loose connections no sign of burn marks etc.
It must be overcurrent but im not sure why would it be the fitting ? but its been fine for 21 years just wondering why now all of a sudden ? could it be cheap light bulbs ?
Any ideas would be much appreciated many thanks volt.
