C
cambria
Hi
I was called to a mobile home last week and the owner said after they switch everyting off at night ALL the lights start flickering on, yes she said ALL the lights. I removed all the light switches to check them and no obvious faults. The way the lights are wired is all the wires are looped into each switch back box and the neutrals stuffed into a choc block connector, a 4 gang switch had 6 neutrals stuffed into one connector. This is how the manufacturer wired this as the home is only 6 months old.
Anyone got any suggestions as to what could cause such as fault ?
