M
martinsayer81
hi guys
i know this is a long post but just wanted to give you a bigger picture of the situation, i appreciate you reading and replying!!
can anyone recommend a type of light fitting that would be suitable for a music studio?
there are no windows and the room is about 4M x 6M, at the moment they have 4 lighting points- each one having 12v track lighting with 3 halogen spots on each.
the trouble they are having is that the lights go on and off randomly, and i think the reason for this would be either a loose connection or the heat from the halogen lamps making the transformer overheat and switching itself off until it has cooled down and then switches itself back on again.
ive checked the tightness of all conections (at the lights, the switch and the ccu) and all seems fine.
so basically i need advice on what type of light to use for this situation, such as: can withstand the vibration from the loud music, dont give off much heat, (the ceiling is lined with fabric) and give off a nice natural light.
the customer doesnt like flourescent lights, thought about led's but might work out a bit expensive,
thanks in advance
thanks in advance
