P
pushrod
Hi, i have an old pendant style light in the bathroom which i want to replace with one that fits the current regs. Bought a light fitting - problem is that it is flush fitting so there is no room for the ceiling rose of the present light. I can fairly easily put it (the rose) in the loft above but is it legal to use the ceiling rose in the loft just screwed to a joist or do i have to use a proper junction box?
Another question (just hypothetical this time) if there was no earth in the lighting cable would it be possible/legal to run an earth as a single to another earth, say on the ring main or would you just have to stick to all plastic fittings that require no earth? Cheers.
