Im looking to put lights in my planter. My thoughts are come off rcd skt into fused spur on outside wall in enclosure , then onto switch, then off too lights. The lights I'm looking at say ip67 which is dead on but assume will have 300mm flex which will need to be jointed which I'm unsure if adaptable boxes with whiska glands will hold out under the soil. I also have spare 2.5mm swa but think is a bit bulky and won't seal as good as a Ip67 gland .
do you think magic gel is necessary?? Can you get ip rated glands for swa?? Any other options I'm all ears ty .
