Lights to come on when alarm is activated (veritas r8) | on ElectriciansForums
Discuss Lights to come on when alarm is activated (veritas r8) in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Am I correct in saying I will need a contactor with 12v aux and a switched 12v supply from the panel to operate the contactor?
I see no problem with using the output of the alarm with activating a 12V contactor or relay, as long as the coil load doesnt take to much and blow the fuse. You also have to make sure the contacts are capable of taking the current from the lights. How many light are you turning on?
It's only going to be switching one light I'm told! but could have multiple lamps so could still be a few hundred watts! Which is like a couple off amp! Can't see the coil blowing the fuse in the panel, but I like the relay method as I'm fitting a speach dialler too which might use the same 12v supply!
I'm pretty sure there's no volt free on the veritas r8, there is defiantly a 12v sw connection which is for latching devices, not 100% if it's even going to work!
Reply to Lights to come on when alarm is activated (veritas r8) in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi. I have a wired Optima alarm. Due to wiring access issues, I need to add a wireless door sensor. Sometime back, I recall seeing a product that...
Shhh, don't tell the Chinese they want a bit of the action.
