Hi folks
whilst carrying out periodics i'm finding lots of instances where normal light switches are installed in toilets (no bath or shower within just a toilet and a sink).
What is the requlation for this please. Is there a minimum distance a normal light switch can be from a handwash basin, toilet etc or are pull cord switches only allowed.
thanks for any help with this
IMO, if the switch is not within reach of the sink, ii.e. the switch and taps cannot be simultaneously touched, then it's OK. i do stand to be corrected , though, if i'm wrong.
Section 7 of the regs gives requirements for 'locations containing a bath or shower' with no mention of a sink or bog.
The building regs state 300mm min from the edge of a sink or draining board for a kitchen, so I'd go for that.
you should not be doing a pir , you obviously dont know the regs well enough
Hi folks
none of us know all the regs. , morph, we still have to look things up, otherwise the IET wouldn't be selling 7671 at £80 a pop.
fair doos
but a bit of a regular basic one really , especially for someone who does PIRs all the time and for years !
so, dean, have you passed these switches so far, or given them a code or a comment on your pir's?
ive only come across this today, i havent finished the report yet. its for a primary school. i know where the regs stand on bathrooms and showers but am unsure about rooms containing a toilet and a handwash basin
i would not code it. just make a note in the comments box if it's close to the basin.
no comment no code Its a nothing Washhand basins arent BATHS nor are they SHOWERS and its NOT a kitchen No Special location applicable
IMO its incorrect BUT then again there are a lot of regs I disagree with and a lot of stuff I think would be more applicable to regs but arent in there
Its the bare feet on a wet floor that can send the tingles down the torso,especially if they are resting on a piece of copper tube
The wet hands folks are still switching toilet lights on
Toilet light switches are ok.Its the fans we need to worry about
I have sat there before now and thanked the gods the fan pull cord was within reach from the sitting position
Now that situation could have killed me if the cord was out of reach
There is no Regulation prohibiting the use of wall mounted light switches in a location that doesn't contain a bath or shower.
A toilet with a sink would be considered no differently to a kitchen,or any other room that contained a sink.
Bath and shower rooms are considered special locations, because often the people using them are naked and wet.
Of course, it is always up to the inspector to determine what he or she considers safe, so if you consider this situation to be unsafe, then you should apply the appropriate code.
The most appropriate Regulation to my mind would be 512.2.1.
So this is a no no then??
This was taken at a new build which I was helping another sparks second fix. They are a switch and a fan isolator switch.
I didn't really like it my self.
first sink i've seen mounted horizontally. bet the customer won't take this lying down.
personally i would put a code 2 on it because the switch is likely to be operated by damp hands, but thats just an opinion.
Given the circumstances (primary school) I would have thought the lights would be switched on in the morning and off in the afternoon by the caretaker, with the people using the handwash basins (children) being prohibited from going anywhere near the light switches.
i would have though taht a school would install occupancy sensors to save money on the bill.
No code or note required in my opinion. Like some have already said a cloak room is not a room containing a bath or shower so there is no mention in the regulations about not being allowed standard light switches. I would still stick to the 300mm recommendation that is referenced in the building regs guide but that is it. I can honestly say that i've never had a tingle off a light switch when operating them with damp/wet hands and i would say that i've been using light switches like this at least 5 times a day for months now.
In accordance with BS7671 there are no requirements not to have a standard face plate in a room containing a sink or toilet. In relation to a periodic inspection, compliance with BS7671 is assured. However if you feel that the location of the flat plate is dangerous then you could code it but it is not a breach of BS7671. It may breach the recommendations of the building regulations but even they do not indicate any problems with toilet sinks.
even less chance if it's further education ( students)
Maybe he doesn't know the regs as well as you, and he won't be the only one, but at least he realises this and has the good sense to ASK when in doubt !!!
Hope no one has wet hands in a kitchen then or we are all doomed letting them cheeky switches get passed us on PIR's
Haha!
The regulation writers are just waiting for the day when they can say you're only allowed in your own house only if you got degrees in Electrical, Plumbing, Carpentry......etc.
Invest in tents now.
shotton, flintshire
lightswitch in toilet
Dean Williams,
ipf,
