This is an RSS feed of thread: Limescale filter resins in internal cold water pipework
Content of the thread: Hi All,
I have an undersink 3-stage water filtration system. The limescale media (resins) leaked into the internal cold water lines. The filter had two sponges, one at the top and one at the bottom, that shifted, causing the media to end up in the pipework. I managed to unblock the tap nearest to the filtration system. However, the tap in the downstairs toilet, the upstairs taps, and showers now have very weak pressure. Moreover, when I open two taps, one of them will not have any water flowing. If I open all taps upstairs at the same time, all of them stop flowing.
Apart from removing an airlock from the pipework, I don’t have any skills related to plumbing, etc. By the way, I tried to use the “airlock” method to unblock it, but had no luck whatsoever. Any advice on what I can try myself, as well as any advice on what I need to ask plumbers to do to resolve the issue, would be much appreciated!
Limescale filter resins in internal cold water pipework to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
