Limit to number of devices on BT Homehub 6 (infinity2)? | on ElectriciansForums
Discuss Limit to number of devices on BT Homehub 6 (infinity2)? in the Computer and Networking Forum area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
After a lot of t-ing and fro-ing, I got a replacement HH6 from BT as the original was disconnecting devices at random.
I was asked on the phone once about how many devices, and when I listed them, they said that was the problem.
As my wife and I both work from home, with 3 kids, I probably have more than is should, but here goes;- (HW) denote
Smart TV (HW)
Sky+ box (HW)
Xbox one
Nintendo Wii
2 x desktop PC's
3 x Windows laptops
2 x ipad
2 x iPhone
2 x android based smartphones
1 x android tablet (seldom used)
2 x Nintendo 3DS (seldom used)
1 x Raspberry pi
1 x Lightwaverf wifi link (HW)
1 x Networked printer (HW, via powerline adaptor)
I doubt very much that the HH would limit the number of connections.
More than likely BT will have capped it in the firmware to try and keep data traffic down, added to that a router made by the lowest bidder...
I didn't think it would be restricted in any way. I don't think I have an excessive number of devices?
It was just when I had a faulty hub that one of the 'experts' on the phone said that could be a cause.
I liked their recent adverts with Ryan Reynolds hanging from a helicopter.... Long range wifi? even straight upward direction? Don't think so. Not unless hub was lieing on its back.
Sounds like a "get out" excuse (or a get off the phone excuse - if you call back the chance of getting the same Tech. is virtually nil!) as long as you weren't trying to use them all at once there shouldn't be an issue with the number.
I don't know that model but most routers have the whole subnet to assign with their DHCP Sever, 250 odd addresses...... look for a setting to reduce the "lease time" of the DHCP assigned IP address (so that if the device isn't on the address can be re-used)
Worth a look anyway.
Everytime I phoned them before, I had to go through their scripted troubleshooting. Not connected to wifi, filter in phone socket, etc etc.
I eventually got a replacement on attempt number 7 I think. When I phoned, their computers were playing up, and I said I wasn't actually at home to perform their troubleshooting. "Tell you what. As you've phoned up about this issue before, I'll send you a new Hub"
Murdoch: I assume I am using both wifi frequencies. When I was having problems, one of the techs suggested naming the 2.4 and the 5 differently, so the devices had to choose one or the other.
If anyone else is having problems with their ISP, persevere with phoning them up, go through their troubleshooting... eventually they will send new equipment. If not, then threaten to change provider.
You need to launch the BT Smart Hub Manager and look at what is connected etc ....
We have a HH6 - its pretty good, better than the HH5 ... and the 3rd Party one I tried with BT
Also you need to establish if you have overlap with your neighbours wifi - download something like :
Free WiFi scanner for windows - Acrylic WiFi Home - https://www.acrylicwifi.com/en/wlan-software/wlan-scanner-acrylic-wifi-free/
Then you can see if a neighbour has a stronger hub than you and is affecting you - this does happen. You can manually set the wifi channel on the BT HH6
If you have kids the parental controls are very useful!
Hope this helps
I'll try the scanner. And set the channel. Although we are a detached house... the neighbours signal isn't as strong.
Parental control is in place. I cant even buy a good bottle of wine online without overriding it. The hub disconnects the kids devices after 9 at night, so I know theyre not instagramming, snapchatting and tweeting into the night (much to 17 year old daughters dismay... I had to change hers to 11pm)
Reply to Limit to number of devices on BT Homehub 6 (infinity2)? in the Computer and Networking Forum area at ElectriciansForums.net
