Limitations on minor works | on ElectriciansForums
Discuss Limitations on minor works in the Electrical Course Trainees Only area at ElectriciansForums.net
Aaron b
Mentor
England
Hello, I need to fill out a minor works cert for a apartment. Is it acceptable or common practice to mark earthing system type as a limitation? The owner isn't around so it's not going to be simple getting access to the buildings incomer. I would assume it tns as the transformer is in the carpark and looks like a private installation.
For context I am changing a extractor fan and light in a shower room and moving a mirror light/shaver socket. The lighting circuit isn't rcd protected so I will be moving it to the rcd protected side.
A call to 105 with the MPAN may provide you with information, alternatively if the supply is communal n neighbours are about, see if they can get you access
Reply to Limitations on minor works in the Electrical Course Trainees Only area at ElectriciansForums.net
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
