W
WDMDL
Is there a readily available current detection device that can be used to disconnect one circuit as the other exceeds a set current? With or without integrated contactor?
This is for use in a large static caravan which has many high-load appliances such as 2.5kW washer, 2kW tumble dryer, 2kW oven and 2.2kW of electric heating.
I want the space heating to be disconnected automatically for the short periods of time that the loading on the socket circuit exceeds 25 Amps, so there is no possibility of the 32A shore supply breaker tripping.
Simon.
Simon.
