T
topcat
As anyone used the line Din rail connectors looking for feed back need to move a CU and extend the cables from where they are now any one else used them and what did you put it in many thanks Tony
Discuss Line Din rail kits in the Electrical Tools and Products area at ElectriciansForums.net
Never really thought about it before as most of my work is industrial, what type of gland do you use for T&E into the box? I can't remember seeing any with a flat oval insert to match the cable.
Don't really need to gland off T&E in this case! Just make sure you don't have cables entering the top of the enclosure, and if you want to be super-duper then seal up the gaps around the cable entry points.
So you just run the T&E in through the 20mm knockouts in the box? I've also been trying to find a box (other than a CU) which has knockouts more suitable for T&E.
used the wago ones, no problem, except difficult to get a conductor out. i imagine the line ones are virtually the same.
edit: fitted a piece of din rail in a 9" x 6" ad. box.
Reply to Line Din rail kits in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
