Line to Earth fault 70 volts?!? | on ElectriciansForums
Discuss Line to Earth fault 70 volts?!? in the UK Electrical Forum area at ElectriciansForums.net
I
iamgary25
Just tested a lighting circuit to find that the voltage between Line and Neutral was 240V and Line to Earth was around 70 volts? What could this be? a short between Line and Earth? Also the circuit is on a 6A 30mA RCBO but doesn't trip, the test button works though...
thanks
Does not compute... you can't have a voltage across a short!
Test kit out ,if you have 70 volts between line and earth your earth is possibly open circuit , and if all was ok and you had a line to earth fault i would expect a Bang !!! so you need to carry out an r1r2 test ,ir test etc
A problem possibly but 70V is hardly indicative of a short circuit.
Maybe the neutral not connected to earth so the system is floating?
Have you checked that?
Reply to Line to Earth fault 70 volts?!? in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
