Line voltage wall thermostat wiring. | on ElectriciansForums
Guest viewing is limited
Discuss Line voltage wall thermostat wiring. in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi all
I'm in the process of replacing some 1970s underfloor heating line voltage sauter wall thermostats with new mechanical replacements (of which there seem to be incredibly few in existence - sauter were very unhelpful with suggestions!).
Anyway I have found a replacement (T4360B1015 for interest), but had a question about wiring.
There is only a single 2.5mm twin and earth wired into the back of the original thermostats. CPC is obviously just CPC, but the other two cores are unmarked - one is black and one is red (1970s colouring).
Aren't these really line and switched line? ie shouldn't the black wire be sleeved red to indicate it's switched live? Or is it possible that these wires are genuinely line and neutral?
Sorry if that is a dumb question.
Reply to Line voltage wall thermostat wiring. in the UK Electrical Forum area at ElectriciansForums.net
It would normally be the outer terminals where the flex of the pendant drop connect.
There is no homework, and I'll never see these photo again.
Recommended Sponsor News
Hi everyone,
