Liquidtight non-metallic flexible conduit. | on ElectriciansForums
Discuss Liquidtight non-metallic flexible conduit. in the DIY Electrical Advice area at ElectriciansForums.net
wyciwug
Falls Church
Hello
can this conduit be used in crawlspace, under the deck outside, and outside running along siding? Will it fail inspection?
Yes it’s legal and it’s outdoor approved by secure it every 3 feet.
Thanks, passed rough in first time. Final failed due to missing ground rod. Complete soon.
  • [ElectriciansForums.net] Liquidtight non-metallic flexible conduit.
Reply to Liquidtight non-metallic flexible conduit. in the DIY Electrical Advice area at ElectriciansForums.net
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
As the conduit is not the sole means of earthing the circuit, the cpc in the cable is… all you need is to ensure the metal back box is earthed...
