G
gaulty
little help on insulation resistance. although i have my 2391 it's been around 3 years since i've tested and have just start a new job where a lot of it is involved.
Instead of disconnecting every emergancy light etc when meggering out a circuit can you twist together the live and neutral of the circuit your testing together at the board then proceed to test between live/neutral and your cpc without disconnecting voltage sensistive equiptment or have a got it completely wrong.
Im sure i read somewhere that this was an alternative method when disconnecting lights etc was not an easy option. My gaffer on site said just test to the light switch but I'm not happy doing that for obvious reasons
Thanks in advance
gaulty.
Thanks in advance
gaulty.
