Live earth fault on every leg of the ring | on ElectriciansForums
Discuss Live earth fault on every leg of the ring in the UK Electrical Forum area at ElectriciansForums.net
Nottingham
Brief run down for you all
Checked end to end of ring that’s sound
Meggered LN sound NE sound LE 0.03
Split the ring same stuff
Split it again same stuff again
Long story short stripped all sockets off on the ring and every single leg has a LE fault
Was rewired 2010
Only logical thing I can think is just a bad drum of cable was used ?
The CU is a screwfix off brand thing so one can only assume it is screwfix special T&E used
Anyone got a better suggestion please let me know left me scratching my noodle for a while
EDIT:
there are no neons
The cable is twin and earth 2.5mm
All sockets were removed ring completely split at every outlet
Any of the following still connected?
neon lights on spurs or switches
surge protected sockets or usb sockets
rcd sockets
rcbo on supply?
That is sounding very much like bad cable. Odd it is just the L but presumably it could have been the brown PVC mix that was contaminated in some way.
I wonder if it was like that new and the installer just ignored it, or if it has gone bad with time?
The rented "anti vandal site office" we have just is a bit like that, but all circuits in the 0.2M region for both L-E and N-E even though not much T&E. Not ours to fix though :(
rcd sockets
rcbo on supply?
rcd sockets
rcbo on supply?
Every thing is disconnected pal literally just legs out the wall and every single leg has a LE fault some 0.03M next one coul be 0.59M one leg was 3.38M but every single leg was faulting
Surge protected extension leads still plugged into each separated section?!
Can you get enough of the T&E to read the manufacturer's details, etc? Wonder if there is ant site with recall information on bad cable.
Not at the minute left my suggestion and findings with homeowner he’s ringing home insurance to see if he can get them to foot the bill 😂
Reply to Live earth fault on every leg of the ring in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
