R
Rasha
Hi Guys, I'm an enthusiastic DIYer, no formal training but can do basic electrical tasks, at least I thought so...
Some advice would be helpful on the cause of a live earth cable on some track lighting I was changing.
The original track lights were low voltage with very old transformers, I wanted to change them for 240v tracks, 3 tracks of 2m each with 3 spots on each.
They seemed to be all separately wired (1.5mm cable) so I removed the transformers and connected the power feed to the existing track cables using junction boxes and for the first 2 tracks all was fine, nice and safe and worked fine.
On the third one I wired up the track then connected up the cables to the junction box and switched on the mains and while testing I found that the earth connection in the junction box was live !
I checked the wiring in the track connector and all is correct so I'm confused at how the earth can be live on this track, obviously I have reached my limit of electrical knowledge and hope you can educate me on this.
Any help or comments would be much appreciated.
