live earth | on ElectriciansForums
Discuss live earth in the Australia area at ElectriciansForums.net
K
kev1387
Hi all, got a problem on a job that i got called out to for another problem, in that the earth wires at the switch and downlighters are live, which is making the metal switch live and metal fittings live? Wondered if anybody had any ideas what it could be before i go back and start ripping up floor boards and looking for fault.
Kev
I agree with the last post, quite a common finding. Try disconnecting the down lights out of the lighting circuit before pulling boards up. You find a lot of problems on lighting is after market diy fitted lights. If some body has wrongly connected a switched live (usually the neutral conductor in a T + E pvc cable) and put it in with the neutrals then you will get a feedback down the neutral and onto the earth via the suppliers intake if it is TNC-S
Reply to live earth in the Australia area at ElectriciansForums.net
Hello What was the conclusion of your problem?
There is no homework, and I'll never see these photo again.
