Hi,
When testing an RCD you have the cover on, on the CU with the circuits energised and test it using a socket on that RCD.
But when there are only light circuits on a given RCD you have the option to test it at the CU or undo a light socket and test it with a Lightmate Testing Adaptor. This way with CU cover is open or light socket dismantled, you are working live on the circuits. How would you convince the assessor that you are working safe? What kind of isolation needs done in this situation? Thanks
