Live works,on DB to do or not to do | Page 2 | on ElectriciansForums
Discuss Live works,on DB to do or not to do in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
what’s your take on working on live DB’S,connecting circuits & installing mcbs.
Even if isolated if you restored the power it still would have exploded yes?
Or was the issue the cover wasn’t reinstated before turning on the mcb?
(I’m not advocating live working by the way)
Actually, no, the problem was that busbar termination screw in the MCB which should have been captive wasn’t. As the guy tried to tighten it it went thru the open side of the MCB and touch the neighbouring phase connection which resulted in a direct short between two phases. If the power had been off it would not have happened.
It's worth remembering that there could be the potential for a substantial fault current which could pose serious risk to personnel working on it. It's actually quite a dangerous practise.
I must say I always work live
The biggest scare I got was when a general operator went to reach over my shoulder, he was mesmerised by the 400 amp copper bus bar.
He was looking to take it home for scrap, ready to ask me if I needed it.
:dizzy:
:dizzy:
Never heard a John Thomas called a 400 amp bus bar before, every day is a school day on the EF website........ no wonder you where scared.......
Don't... I did a job on Saturday adding a couple of socket outlets in a nice house in Newport. The lady of the house asked a question about the testing (insulation resistance at that stage) whilst I was at the open consumer unit.
"Ooh, look at that cobweb" she said as she reached into the consumer unit and swept it away with a finger, just above the live bus bar!
Reply to Live works,on DB to do or not to do in the UK Electrical Forum area at ElectriciansForums.net
Thanks, I was reasonably confident but nice to confirm. That was the original install getting power to the outbuilding, done by an electrician we...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
