Hello to everyone, and excuse me for the stupid question
I have a valve in my cooling system that I need to disable every now and then so my acc heater heats the engine as well as the cabin.
Anyway.
The valve is 13ohms has a consumption 1amp and runs on 12v.Is it all right if I connect a resistor with same resistance on the leads so the module doesn't detect a fault or is there a better way.
What wattage should the resistor be, the valve looks like its 12w, so same or more ?
Thank you in advance !
Anyway.
