Load testing alarm batteries. | on ElectriciansForums
Discuss Load testing alarm batteries. in the Electrical Tools and Products area at ElectriciansForums.net
M
mdshunk
Anyone got a link to an alarm system battery checker? Using a regular DMM doesn't necessarily cut it, for me, so I've been putting a load on alarm batteries with an incandescent lamp during the annual PM to check them. ELK makes an alarm battery checker that relies on baseline measurements from when the battery was installed new, which is somewhat unrealistic considering that I might not have been the one to put in the new battery. I've got a decent one for UPS batteries, but it doesn't go low enough to check the 4 - 7.5 amp-hour batteries normally found in security/fire/access control panels.
Reply to Load testing alarm batteries. in the Electrical Tools and Products area at ElectriciansForums.net
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
