Hello Troops,
This follows a thread from last week about SNE supplies, and many thanks to Tony for already having looked at this off forum just to check I'm not going mad!!
We get on a weekly basis someone posting about loading and worries, and we politely tell them about diversity and yes it's witchcraft but it works and nothing to worry about. Until now!
This is a new-build that I'm currently doing. It's a complex site - just one house, but several outbuildings and the big thing is that it has NO mains water or sewerage. So, there is a plant room which runs bore hole pumps, purification, a ground source heat pump and some other bits of jizz. The mains intake is an 80A TN-S with a Ze of .67 (not that that matters to this). It comes into the plant room to a main DB, and is then distributed around as required via SWA on site.
The house supply is via a 63A/2 mcb which limits that bit by default.
The ground source unit is quoted at 41A max and contains instantaneous water heating.
Water treatment works come in at around 20A.
Remember - this is a domestic, not industrial. Take a look at my spreadsheet and those with a few years on them please offer any advice you can! I already have this flagged for investigation with the DNO, btw, and the supply was installed before my involvement.
View attachment loading schedule.pdf
