Location of fused spur? | on ElectriciansForums
Discuss Location of fused spur? in the Central Heating Systems area at ElectriciansForums.net
R
raymocrjd
Are there any regulations against fitting a 3 amp fused spur below a bolier?
Location would be between the flow and gas pipe.
Cheers, Rob.
should have a minimum spacing from gas and water pipes. think it's 150mm.
Reply to Location of fused spur? in the Central Heating Systems area at ElectriciansForums.net
The pics you put up of the consumer unit are all good .....all circuits RCBO protected and as above swap the fuse out for a 3 amp
Electric hob/oven range was installed years ago, runs on 2 x B32 MCBs to 'House' (sub)consumer panel, runs to oven on 2 x T&E. Kitchen is being...
