shifty
Hey guys I was hoping you guys could clear some issue up for me ive been asked to snag one of our properties that has be refurbed recently but not being a tester my rules and regs knowledge is a bit lacking.
So basically its all about spurs for isolation
1. spurs are required to isolate fridges washing machines etc so they can be safly pulled out to work on but where should they be located as the spurs in the property are in a cupboard (still in the kitchen) is that ok or should they be near by the appliance there isolating.
2.The spurs in the kitchen are on a large moduler grid plate but ive been told that this doesnt comply as the switchs will only be rated at 20A where as a spur is 32A therefore the supply circuit to the spur should be a dedicated 20A supply is this correct.
3.in the living areas there are AC units (floor standing) which are boxed in using some designer wood they lift of easy enough but the issue we are arguing about is the spur is inside the boxing not outside is this ok or should it be outside.
All these points need to be a 100% with the regs even if we dont aggree with them so we can throw them in the builders face without any comeback.
Any help would be appreciated.
