I'm fitting an en-suite cc wc in the small bedroom and I'm tight on space. Is it doable to fit a macerator beside the wc?
I'm thinking of something like a 'McAlpine WC-con8f flexible connector' or would it be better to use non-flexible fittings?
Also the pan has no screw holes for fitting so it's going to be glued down, this is new to me and another reason to put the waste unit beside the pan. Perhaps there's a hack to fitting this wc without gluing to allow access to a maserator behind the pan?
Continue reading...
Continue reading...
