Good evening all together.
I am planning a new supply for a new cooker. In the 'On Site Guide' it says the oven swtch (with socket
outlet) has to be 2m away from the appliance, that would be right in the corner of the kitchen.
I assume the switch has to be located over the work top for adequate access. But, the actual termination point for the cooker (I use 10mm twin and earth via 40 A B type mcb) can be closer to the appliance, say behind the cooker? If it has to be straight underneath the switch then it would be underneath the work top behind a cup board. Can I spur off a socket for the extractor hood from the same supply?
And where would be the ideal location of the termination point for the hood be? The on site guide is a bit poor in this case. Any suggestions?
Thanks guys.
Thanks guys.
