Locking off wire? | on ElectriciansForums
Discuss Locking off wire? in the Electrical Tools and Products area at ElectriciansForums.net
P
pencilpusher
Can anyone suggest a locking off device (preferably a wire) for locking off an small isolator switch provided by the DNO at the cut out. All my lockout devices are too big for a little switch. I cannot see how to lock it off apart from it has a small hole in the screw holding the lid on the isolator. A bit similar to the hole through the screw which is sealed. Thanks. PP
i would assume that hole was for an anti tamper seal, not to lock off the isolator.
[ElectriciansForums.net] Locking off wire?
I agree its for a seal but I cannot think of any other way to lock this off. The switch underneath is too small for the normal locking off devices.
Thank you for taking the time to look. I tried but could not see anything that would suit. I cannot believe that they offer an isolator for convenience (great!) but do not think about safety!
I shall have to park my dog next to it to fend off anyone who approaches!
You won't find anything that replaces that, however you might be able to have a custom made screw & tab made up to suit it if you're working on them on a regular basis. I'm thinking a Z shaped bracket that has a hole in it, and a larger head screw with a hole through it. So when you screw it in (which you can do by finger I'd imagine if the head is big enough for a padlock, it lines up with the Z-shaped bracket. Padlock it and it'll be impossible to remove due to the Z of the bracket hooking over the edge of the unit.
What a bloody good idea. Did not even think of that. I have now seen them and they are perfect for short term use. Thanks to all.
They don't really prevent anyone reasonably determined from turning it back on then, while a lockoff does give a degree more protection.
I agree but it is sort of locked off! If they wanted to remove a pad lock, they could do if determined. This is a "barrier" and along with a sign fiited I hope it will let the nosey people, who may find themselves in the meter cupboard, realise that they need to keep their hands off whilst I am working!
I am grateful for all those who have tried to help me.
Regards PP
Reply to Locking off wire? in the Electrical Tools and Products area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Hi and Welcome to the forum! Sounds like you keep yourself busy in your retirement!
