shiner
Hi everyone,
I have just got back from my friends place, he is doing a loft conversion. i noticed that he has run the new wiring for the lights and ring main out. but my concern is that he has run it under the new joist and on top of the insulation. For the lighting circuit it is between the insulation and the eves of the roof.
I thought you had to run the cable clipped to the joist and drill a hole through where required and to keep it away from the insulation.
i thought i should just check before he got to the point of no return.
