Just finished a small conversion in the loft and been running an extension lead up to a light.
I'm looking to put a switched light in there and just want to check my thinking is right.
I put a light in the loft running a new wire down to the bedroom switch that is currently a single switch. I am looking to have a double switch in the bedroom
so assume the second switch I wire red top com and black as the switched to bottom L1 then jumper the com on 1st live com to 2nd com?
If that thinking is right then the live and switched go to rose of the light with blue and brown on light connected accordingly?
The question if the information I have given is right is do I run a neutral and earth wire from the existing bedroom ceiling rose to the new light to provide the neutral live connection or will it work without doing that?
I'm not to bad with electrics but adding a new light to an existing switch as described ( not a two way ) has me thinking.
Any thoughts or a diagram maybe?
Cheers
Cheers
