Loft light? | on ElectriciansForums
Discuss Loft light? in the Australia area at ElectriciansForums.net
SparkSmog
Im going to install a light in my loft, anyone got any reccomendations of which light fitting to use? Im assuming id just be able to take t&e off the upstairs lighting circuit and run it to it?
I usually do industrial work so not to sure about things like this so any help is appreciated
I cant see a Problem with it (not saying there arnt any). As long as its clipped and not strung across i think it will be fine, Maybe stick it on RCD or RCBO just to cover ya self! Although if its in surfice i dont think the regs require it.
I repaired mine - previous owner had taken power from a ceiling rose but in the process had broken the fitting so replaced that and took the power via a junction box instead, clipped cable to joists above insulation and put in a cord pull switch that hangs close to loft entrance so can put the light on the moment you open the hatch.
I would take the supply to a switch( pull cord or standard )
You can then use a switch with a neon
It helps rule out having a nagging feeling a few weeks later that you left it on
Fluoresent light or 2 or more every time for me
Reply to Loft light? in the Australia area at ElectriciansForums.net
It's actually all a bit academic as the grey twin and earth cable shouldn't be being used outside (not UV rated) so really the whole lot needs...
At this "first" fitting it's loop in. The rest appear to be joint boxes and old par 38 light fittings. It is reasonably old wiring but not...
