logic + wiring | on ElectriciansForums
Discuss logic + wiring in the UK Electrical Forum area at ElectriciansForums.net
M
MARKY
Hi could anyone help need to wire a seimens RWB30 timer centre EHE0200155 stat to a ideal logic+ combi boiler..please could you help with the connections??? reaslly dont want to blow the PCB
L-N-E to timer either from boiler or fused spur, then a live and switched live from timer to the boiler, somewhere near the terminal block for the incoming L_N_E, there will be another terminal block with a link across remove this link and connect you live and switched live from the timer, these boilers are 0-24v so do not fit the link in the programmer.
Hope this helps and makes sense
.http://www.industry.siemens.co.uk/b...controls/documentation/Documents/rwb30e_i.pdf
Reply to logic + wiring in the UK Electrical Forum area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
