Long Lead Cheap Alternative Suggestion | on ElectriciansForums
Discuss Long Lead Cheap Alternative Suggestion in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
daver
Just a general as to what people are using for long lead testing. Not made a purchase yet, but refuse to pay the £70 or £80 megger and Kewtech want to charge for a 30M roll of cable with some banana plugs on the end.
What is a cheaper alternative.
Got banana plugs and sockets, what would be a managable cable to use.
Cheers
Dave
I just use a roll of 2.5 single and put it on a reelable drum like an old extention lead drum. couple of connectors and r2 tests are sorted cheap.remember to null out or subtract from test result.
Think there was a thread regarding this not long ago.
regards
Tony
That was my thinking, I was just looking for a more flexible cable. I know that the megger uses silicone multi strand, so very flexible. But trying to find that cheap is impossible. Did find some PVC multistrand 2.5 which is very flexible and around £15 but then need a reel. Just seeing what everyone else uses.
Cheers
Cheers
just a thought but could try maplin
try this
WANDER LEAD / WANDERING LEAD ADAPTER SOCKET on eBay, also Parts Accessories, Test Measurement Equipment, Electrical Test Equipment, Business, Office Industrial (end time 14-Feb-09 07:32:35 GMT)
Basically it converts any extension cable into a wander lead. Cost is £9.99 plus postage. I used one for a while and as it worked fine, not quite as convenient as a Kewtech but not far off. And a hell of a lot cheaper.
Will
cheap as chips !!! wot a gud idea !!!
Made one of the adapter sockets today.
Socket 95P. Banana Socket about 20P.
Bit of 4mm earth and Glue Gun
Total Cost £1.15
Cheaper than Chips
try this
Will
Bought one myself off ebay. It works great with my extention cable on drum.
Reply to Long Lead Cheap Alternative Suggestion in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
