Long method de rating factors | on ElectriciansForums
Discuss Long method de rating factors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Lincolnshire
Having used Amtech for so long I can't remember if the de rating factors are applied to the design current or the tabulated regs current, can anyone give me a refresher example calc, I guess it has to be tabulated if it's a current reducing factor
You times all the derating factors together, then divide the rating of the selected protective device by that sum.
[ElectriciansForums.net] Long method de rating factors E.g In / (CaĂ—Cg)
In = protective device.
Ca = ambient temperature.
Cg = grouping factor.
Obviously there's are various other rating factors to be considered.
Reply to Long method de rating factors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
