Long right angled screwdriver plumbing advice | on ElectriciansForums
Discuss Long right angled screwdriver plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Long right angled screwdriver Hello,
I want to tighten a screw at the back of a radiator. Instead of removing the radiator, I thought it would be better to use a ratchet screwdriver or a right angle screwdriver. However the screw is at 20 cm depth. I would appreciate any advice from you on the best tool to use to tighten the screw instead of removing the radiator as i can't find as long right angled screwdriver / ratchet screwdriver. Thank you.
Thank you.
Long right angled screwdriver to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Long right angled screwdriver plumbing advice in the Plumbers Forums area at ElectriciansForums.net
B
Draining radiator? I’ve got this radiator that I need to drain down & remove to clean out due to sludge. Can I drain it with that drain valve on...
ben100
B
Z
Radiator valves question Hi guys, got supplied some corner valves but they have a rubber to go into the radiator inlet to create a seal. Well I...
Zach054
Z
