Long wood bits | on ElectriciansForums
Discuss Long wood bits in the Electrical Tools and Products area at ElectriciansForums.net
L
liam b
Ive got a couple of jobs coming up where i need to fit light switches and sockets downstairs in new builds with concrete floors and timber frame walls, im after a long wood bit i can drill down into the walls with from the first floor so i dont have to make any cut out in the walls to get past supports/braces are 1000mm wood bits available anywhere? Or what other methods do people use to avoid disturbing the plaster board?
cheers :)
cheers :)
"Hello liam",
Toolstation sell 400mm long Flat Bits at very reasonable prices - cheap enough to not have to worry about using an extension bar - and not having to worry about the Flat Bit coming out of the extension bar within the Hole.
Here is a Link to the Toolstation webpage where these 400mm Flat Bits - various sizes - are shown:
Toolstation > Power Tool Accessories > Wood Drill Bits > Extra Long Flat Wood Bits [ I think that cat. no. is for a 19mm one]
I hope this helps - I doubt whether You will be able to find Flat Bits longer than this without going to a Specialist Company - and then because they would obviously have to be manufactured from a higher quality Steel regarding the Torque resistance etc. - You would no doubt be looking at `Expensive` Items.
There MAY be longer Auger Bits / `Twist Bits` on the market [?] - where there is a section of Spiral Twist [with a pilot screw] and a long `shaft` - I have some of these 450mm long - but I have never seen any 1000mm long.
EDIT: Here are some Drill Bits to possibly do exactly what You want - although they are NOT Flat Bits [but probably better as 1000mm long bits]:
Here is a Link for a website where they sell `Machine Cavity Wood Drill Bits` - 1000mm Long X 120mm Drilling Depth [that is what is stated as the specification for `Depth of Drilling`] in various Diameters.
http://www.hall-fast.com/consumable...machine-cavity-wood-drills-length-1000-120mm/
These are stated to be suitable for Drilling through Cavities / Joists etc.
Regards,
Chris
Thanks for the replys, that auger bit is just what i need thanks. Ill be buying a couple of extension too.
"Hello liam b",
I thought that the Link that I edited into My message was to 1000mm long Wood Bits [120mm `Drilling Capacity`] - ?
I hope that you find them ideal to do what you want.
Regards,
Chris
Reply to Long wood bits in the Electrical Tools and Products area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
