Looking at this map - it tells the story! | on ElectriciansForums
Discuss Looking at this map - it tells the story! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Well not really, it's a subset of those installers who use the PaperClip software. So there are no installs at all in or near Cambridge if you believe this ;)
Reply to Looking at this map - it tells the story! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
All socket outlets up to and including 32A (which are commercial, not domestic) are required to be 30mA RCD protected. By the sounds of it you...
You can use timers to turn ON/OFF circuits during the day to maximize your self-use of solar power. Turn ON low draw circuits such as a 1Kw pool...
