G
gerbil
I went to b&q looking for a fluorescent light to fit in the attic but as the b&q staff wasn't helpful i was wondering what is the best between a 5ft 58 watt diffused electronic fluorescent light and a 5ft 58 watt slimline electronic fluorescent light. As i'm no electrician i was thinking of wiring the light up and putting a plug on the end or would it be easy is it for a diyer to fit the light up in the attic
Due to current regs you will have to fit a 13A plug to the end as you need to be Part P registered to extend the lighting circuit (minor works). Could be a pain dropping the hatch and plugging in every time you go up. Best bet is to get it done properly with handy switche/s, it wont cost you much in the grand scheme of things.
Quote " Adding lighting points (light fittings and switches) to an existing circuit" note f applies. Attic is not a special location page 21 guide to building regs
Chris
Yes, that's what I thought was correct. Part P was brought in to help combat rogue kitchen and bathroom fitters, people who don't bother with safe zones etc., just bang it in and b***er off.
It was the kitchen utensils Rack in the kitchen, sorry it was in a conservatory to the side of the open plan kitchen diner the husband put the rack up 3 years prior to the accident poor bloke.
Just realized that sounded rather Cludeo ish.
Seeing as your a DIYer thought I would mention that 13A plug, if used, needs to be fitted with a 3amp fuse, 5 max. Fellow sparky's would know this, you might not. ;)
Looking for advice on fitting light in attic
Australia
gerbil,
spamwize2,
