Looking for advice with a self made c/u | Page 2 | on ElectriciansForums
Discuss Looking for advice with a self made c/u in the UK Electrical Forum area at ElectriciansForums.net
Afternoon, I've spent the day looking for an ip55 or above 6way single phase c/u... Its to be installed inside an enw substation and from past experience they don't expect the metal enclosed c/u, so long story cut short, I've got an ip65 enclosure with dim rail but I'm not sure how to fit a neutral and earth bar as its not come with them.. .. Any advice would be much appreciated
I have actually considering I work for the electricity network... Clearly you haven't because any dno set out the standard regs plus there own twist ie ip ratings ect..
All my work is at power stations and occasionally subs but I'm normally on HV/EHV with transformers and switchgear. I should have put a ;) on my last post as I've seen some of the work on sites that certainly wouldn't come up to current, or for that matter, previous regs. Some of it is quite new install stuff too. Not by me I should add :)
Fair enough, thought there was a snide comment there ..... I work in power stations and subs lv and hv, I do the lv terms, hv terms and small wiring ... I work under enw, ukpn npg and wpd and all have had different spec
No, not directed at your work at all. It was towards the normal 'standard' of site engineer installed equipment. I've yet to come across a site engineer who has any 'normal' electrical qualifications. Most of them would believe you if you told them the 14th edition was the latest release :eek:
Reply to Looking for advice with a self made c/u in the UK Electrical Forum area at ElectriciansForums.net
