Looking for electrician to swap MCB in OL10 area. | on ElectriciansForums
  • If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
You're viewing the old forum category for electricians jobs. That's fine and you can reply to threads and contact the person who posted the jobs etc too. But for new electricians jobs post to the new job forums instead; Electricians Available for Work Post Here, People seeking domestic electricians post here, People seeking Commercial or Industrial Electricians post here
Discuss Looking for electrician to swap MCB in OL10 area. in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
JakubKot
Manchester
Job Type Offered
One-off Job
Hi.
Im looking for electrician to swap mcb in my consumer unit for one suitable for single phase welder with max input current of 16A. In my consumer unit there is 32A type B mcb that was used with electric shower that is disconnected. I need it swapped for 16A type C (been told its a right one). Welder will use interlocked 16A socket on wall of garage that is part of house. I'm planning to use 4mm cable about 7m long. I need electrician to provide and swap suitable mcb. Consumer unit manufactured by Live Electrical.
Job in Heywood OL10.
if your 4mm cable is installed clipped direct. not in insulation, the 32A MCB can stay.
the MCB is there to protect the cable from overload. 4mm cable is rated at 32A ( ref. method applied). using the equation Ib<In<Iz, ...16A<32A<32A, (the<symbol being equal to or less, can't do the proper symbol on pc.)
A 16A socked should be protected by a device not exceeding 20A. This can be applied where the circuit incorporates more than one socket, for a single point a 16A device makes sense not 32A.
that's debatable. the MCB is to protect the cable, not the socket. OK. BS1363 sockets are protected (downstream) by plug fuses, wheras toe 16A socket is not, but I'm sure a 32A MCB would trip before an overload is sufficient to destroy the socket. is there a reg. to dispute this?
I'm sure you could argue that the regs allow it, but I'd say common sense needs to play a part in this. Why wouldn't you want to protect a 16A socket with a 16A ocpd?
ideasl situation is a 16A or 20A MCB. my point was that OP could leave the 32A in, esp. if there were other outlets on the circuit. in this case it seems that it will be a dedicated circuit so, yes reduce the In to suit.
[automerge]1569852032[/automerge]
a bit off topic, but according to Wylex in an article in PE, they say that a AFDD negates the need for a RCD. I can't see how.
Reply to Looking for electrician to swap MCB in OL10 area. in the Electricians Jobs area at ElectriciansForums.net
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes. We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world. Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
Also note that we have tiling jobs, and plumbing work too.
