Looking for G9 to G4 adapter | on ElectriciansForums
Discuss Looking for G9 to G4 adapter in the Lighting Forum area at ElectriciansForums.net
YossiD
Israel
I have some lighting fixtures with G9 sockets that I want to use for outdoor 12V LED lighting. After extensive searches I have come to the conclusion that there are no 12V G9 LED bulbs, only G4. Nor have I managed to find any G9 to G4 adapters. Does such a thing exist?
Due to the structure of these fixtures, it is not possible to replace the G9 sockets with G4, as the sockets have an outer thread with a bushing that holds a heavy glass shade.
[ElectriciansForums.net] Looking for G9 to G4 adapter
In the meantime, I have tried soldering some thin brass strips to the G4 bulb pins and that works ok, but it's definitely a nuisance and I'd be interested in other suggestions.
Like you I thought G9 bases were exclusively found on mains voltage bulbs. It's true in retail shops.
But there seem to be 12V or 24V LED versions for special applications, eg camper vans and boats.
I suggest you keep looking, e.g.
Expensive though!
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Thanks for the reply.
The low voltage G9 bulbs appear to be out of stock on Amazon, and I have no idea if they will ship to Israel. Didn't find anything similar elsewhere
In the meantime I've ordered some of these on AliExpress (~ $2/bulb in lots of 10).
They claim to be 12V/12W dimmable, though I doubt they'll be as bright as the wattage suggests - no lumen value provided. Time will tell.
Here's my prototype G4 to G9 conversion. Not very elegant (I need to work on my soldering skills) , but it works well so far. Fortunately I have some suitable brass shimstock lying around, and luckily the G4 pins are solderable and can be bent without snapping off.
Any idea why G9 are not readily available in low voltage versions or why there's no G4 to G9 adapter? The G9 certainly seem more robust than G4.
Expensive though!
Reply to Looking for G9 to G4 adapter in the Lighting Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
