Looking for mft 500mA fuses | on ElectriciansForums
Discuss Looking for mft 500mA fuses in the UK Electrical Forum area at ElectriciansForums.net
RS components you can order online or collect over the counter - reminds me I need a few spares.
Hi guys , does anyone know anywhere that stocks mft 500mA 600v fuses ?
Cheers
Contact the manufacturers of the MFT or check the instruction manual for spares availability, should be a simple operation to find the right fuse. You could have tried Maplins, but they are no longer with us.
Failing that most electronic based repair outfits may be able to help. I see someone mentioned RS a good starting point I should imagine.
Reply to Looking for mft 500mA fuses in the UK Electrical Forum area at ElectriciansForums.net
Hi Richard Thanks for the reply, it won’t function as it will with the MFT1741+ but will I be able to use the MFT 1721 and perform all the...
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
