Hi,
So I am currently troubleshooting a cummins generator that only seems to be able to switch from idle and rated speed mode during only after running for about ten minutes, any longer than that everytime i switch back to idle from running, there is no change and when i change it back to rated, the rated speed increases by about 100rpm, i remove the 24v battery and wait for awhile, when i restart the engine, all the settings are wack and I have to tune the governer settings back to normal i.e. idle and rated speed, however the same issue occurs, at the start i can switch modes fine, after awhile, the same problem occurs, I've connected the wires correctly according to Cummins manual and have replaced the governor controller and actuators, has anyone any insight on this problem? Or if anyone has a more specific datasheet for cummins governors other than the official manual, that would be appreciated. Thanks
Also, i find it weird that when the terminals for idle and run are connected, its running at rated, and when idle is disconnected from run, it runs at rated.
