Darkwood
Arrived at a factory today to a what should have been a basic problem with a motor, and was introduced by the so called 'Maintenence electrician' who took me to the offending motor, first impresssions were the motor connector housing and block was smashed, he relayed to me he couldn't get hold of one to fit so i did a little testing to first check motor was ok when i noted it was in star connection but been 11kw motor of this nature it should have been delta connected, it tested ok but i connected in delta and ran it but it kept taking out the front end mcb as expected, after explaining this to him that it needed sorting and due to supply limitations i would fit a soft start, he said "theirs nothing wrong with the way its done and ask what a 24 yr boy could know"
"well im 37 been repairing motors 15 yrs and cos this motor only run at a quarter of its potential is the only reason why it didnt burn out" with that he walked away and i later found out hed designed wired and installed it and was proud of his achievement
I hate wannabe sparkies but got my own back when i told the bosses the repair quote and why.
