M
mpelec
Hopefully someone can answer this query for me.
I'm more used to domestic installations but have taken on a job in a workshop. The workshop is around 80m away from the intake which is a 3 phase TN-C-S supply. The workshop is new but I'm using an existing 16mm 4 core SWA cable. I'm using the SWA as the earth. The ZE at the origin is within limits but when measured on the workshop DB I get 0.70 ohms, I'm guessing due to the length of cable & that I'm using steel rather than a copper conductor.
When measuring ZS at the sockets etc I'm getting a higher reading than those allowed in table 4.1.2 of the regs for type c rcbo's. If I changed the rcbo's for type b's the readings would be within limits but I'm worried they would trip with an inrush of current.
Any ideas? Thanks, mpelec.
